Aug 15th, 2024, 12:37pm
CMOS PA parallel power control? (Read 4085 times)
Visjnoe
Jul 01st, 2009, 8:55am
I'm looking into some possibilities for designing a CMOS PA @1GHz
(no prior experience). I have read some papers where the power is controlled by combining the output power from different parallel
stages, but they always use a transmisson line and/or matching network
before the power is combined.
I was wondering if it's not possible to connect different open-drain (cascaded) output stages directly together and enable/disable them
for power control. So all parallel stages would share 1 common output node which is connected to the output matching network.
Peter
Re: CMOS PA parallel power control?
Reply #1 - Jul 1st, 2009, 9:26am
Visjnoe wrote on Jul 1st, 2009, 8:55am:
for power control.
Possible.
See Fig 5.26(Fully digital amplitude control through multiple-switch transistors) of the following.
http://www.amazon.com/All-Digital-Frequency-Synthesizer-Deep-Submicron-CMOS/dp/0...
Or see http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?isnumber=29863&arnumber=1362836&c...
But there are two issues at least.
(1) Output impedance will be changed by power control since active transistor numbers are changed.
(2) Input capacitance is fairly large even for small power mode.
And there are many methods to realize on/off transistor.
Visjnoe
Reply #2 - Jul 2nd, 2009, 12:00am
Dear Pancho,
thank you very much for your reference papers, it was exactly the kind of material I was looking for.
FYI, in the meantime I found another publication (by Rofougaran and Abidi) where a similar approach is used for discrete power control of a PA:
http://ieeexplore.ieee.org/search/srchabstract.jsp?arnumber=586252&isnumber=1272...
Kind Regards
Peter
waseda-rfic
Reply #3 - Jul 2nd, 2009, 1:34am
in this way, it has more output power than a single PA.  transmisson line or transformer is for power combining and match.
Visjnoe
Reply #4 - Jul 2nd, 2009, 4:48am
Dear Waseda,
I think I'm missing something here: what's the difference between power combining the output power of different PA/stages and controlling (increasing) the output power of 1 PA using different parallel stages?
I mean, I understand what the difference is, but for what reason would one prefer one method over the other as a means of power control?
Peter
waseda-rfic
Reply #5 - Jul 2nd, 2009, 5:54am
Visjnoe wrote on Jul 2nd, 2009, 4:48am:
If output power is not so large, you can use one PA with output power control. but for large output power, one PA is not enough, you have to use power combining technique. And you can control each PA, and also you can make controlling within each PA if needed.
