Jul 18th, 2024, 3:26am
AC response & step response simulation of a switched-capacitor amplifier (Read 1891 times)
rajeee1000
Bangalore
Jul 01st, 2009, 10:49pm
Hi All,
I am trying to simulate the frequency response of a switched capacitor amplifier. For this, I have replaced the dynamic CMFB of the opamp by an ideal continuous-time one and  I have frozen the clocks to amplification mode (that is, now the amplifier has the capacitive divider feedback around the opmap). And I am biasing the input nodes of the opamp to the right common mode through BIG inductors.
With this configuration, if I run .OP, the simulation shows convergence error. I need some help to fix this. Is there any fundamental issue with respect to such a setup to characterize the switched-capacitor circuits?
Thanks & Regards
Rajesh
buddypoor
Bremen, Germany
Re: AC response & step response simulation of a switched-capacitor amplifier
Reply #1 - Jul 2nd, 2009, 5:08am
rajeee1000 wrote on Jul 1st, 2009, 10:49pm:
............ and  I have frozen the clocks to amplification mode (that is, now the amplifier has the capacitive divider feedback around the opmap). ............
Rajesh
I´m afraid this cannot work since - for my opinion - there is no "amplification mode". You cannot use only one "frozen" switch configuration and expect at the same time a reasonable behaviour of the opamp.
Instead you have to apply the classical ways for ac simulation of S/C circuits : Specific s/c oriented simulation routines as e.g. in spectre or replacement of all s/c blocks with corresponding time continuous linear blocks.
