mmzaj
Hi
i know that the Amp in the attachment is a long-tailed pair limiting Amp . but i'am having a hard time trying to figure out the role of the capacitors !! the Amp should be functioning in the switching mode - the designer says so - , but capacitors introduce a "decaying" output !! also , is it a good small signal Amp , or should i expect only a square wave at the output ? a detailed analysis would be nice :) btw , R2 is connected to a +12V Vcc .
