Aug 19th, 2024, 12:23pm
UGB requirement for Bandpass filter (Read 3256 times)
manodipan
Jul 14th, 2009, 6:42am
I have a doubt on the UGB requirement for a Bandpass filter ...let's say center frequency is around 3MHz and Qfactor=1.5....what should be the requiremnt of opamp UGB ???is 100MHz UGB is okay??Thanks a lot...........
raja.cedt
Re: UGB requirement for Bandpass filter
Reply #1 - Jul 14th, 2009, 8:34am
hi,
   i think it is  depends on the architecture..but roughly you can say its around 20MhZ, but 100 is too much..it consumes lot of power.
thanks,
rajasekhar.
aaron_do
Reply #2 - Jul 14th, 2009, 8:49pm
an ideal op-amp based filter only has a feedback path. However, a real filter will have a feedforward and a feedback path. The UGB of the loop gain will determine up the what frequency the BP filter will behave ideally. Beyond the UGB of the loop gain, the feedforward path will start to dominate, and the filter transfer function will no longer follow the ideal transfer function.
So the UGB requirement of the loop gain is determined also by your interferer profile and possibly noise requirements.
Also remember that even if the transfer function continues to roll-off after the UGB of the loop gain, the linearity will not be good at these frequencies.
cheers,
Aaron
BTW as Raja mentioned, if you overdesign the opamp, you will pay for it with higher power consumption.
ray_wang
Shanghai
Reply #3 - Jul 23rd, 2009, 9:33pm
raja.cedt wrote on Jul 14th, 2009, 8:34am:
hi,
thanks,
rajasekhar.
i don't think 20Mhz would be enough unless u use some Q-tuning techniques. The peaking is significant with only 20Mhz UGB.
raja.cedt
Reply #4 - Jul 23rd, 2009, 10:24pm
hi,
   i assumed that sallen key filter so roughly i gave that no..but i don't think peaking will come...could you please explain more
rajasekhar,.
ray_wang
Shanghai
Reply #5 - Jul 23rd, 2009, 11:03pm
raja.cedt wrote on Jul 23rd, 2009, 10:24pm:
hi,
rajasekhar,.
Peaking is proportional to biquad Q and inverse proportional to opamp GBW. See a paper on filter written by several Japanese in JSSC, Nov. 2007.
