Aug 19th, 2024, 4:22am
confusion over an input signal of ADC (Read 2990 times)
icekalt
Aalen, Germany
Jul 16th, 2009, 1:53am
Halo,
When we say an input of 1.4Vpp, we can say that it is a sinusoidal signal from 0.7V to -0.7V. For folding ADC, the input is firstly connected to gate of differential pair. When the input voltage at the gate is from -0.7 to around +0.5 volt, the transistor is actually off. But we always want it to be on. I'm really confused over this. Can someone explain to me?
yvkrishna
Re: confusion over an input signal of ADC
Reply #1 - Jul 16th, 2009, 10:18am
hi icekalt,
You are correct that the trans would go off, but the inp signal will be riding over a commonmode voltagel(DC voltage) to bias the transistors in saturation. And also most of the times the implementation is fully differential.
Vamshi
icekalt
Aalen, Germany
Reply #2 - Jul 16th, 2009, 11:23am
yvkrishna wrote on Jul 16th, 2009, 10:18am:
hi icekalt,
Vamshi
Thx very much
so, is it ok to have -0.7 V to +0.7 V(1.4Vpp sinusoidal) input signal of diff. amp?? when i simulate the operating point, DC at the gate of transistor is 0 V
yvkrishna
Reply #3 - Jul 16th, 2009, 11:43am
what is the technology node and nominal supply voltage ?
please post the snapshot of your circuit. Not clear what you mean by DC at gate is zero.. we have to apply additional DC voltage(for biasing trans in saturation) in series with signal voltage while simulation.
« Last Edit: Jul 16th, 2009, 1:06pm by yvkrishna »
icekalt
Aalen, Germany
Reply #4 - Jul 16th, 2009, 12:48pm
yvkrishna wrote on Jul 16th, 2009, 11:43am:
0.35µm and 3.3 V supply voltage
currant
Reply #5 - Jul 16th, 2009, 11:39pm
I think so:
 1. If differential signal has Vpp=1.4V, then signal on one line has Vpp=0.7V. So we feed a signal ±0.35 V to a gate of transistor.
 2.Of course, we need apply to input of diff amp not only diff signal, but common mode voltage too. Vcm serves   as DC offset of input stage (another variant, when dc offset is internaly formed, feed input signals through decoupling caps).
