I'm assuming the convergence failure you're talking about is during the transient, rather than DC (otherwise the integration method would not affect it)?
If so, it could be that there is some instability in the circuit which gear2 is damping; this instability could be real, or it could be as a consequence of poor models (either transistor models, or sometimes things like non-linear resistor models with multiple solutions, one of which is completely non-physical).
It's virtually impossible to tell what the root cause is without seeing the netlist and models. If you can't post it here, you might want to contact Cadence customer support to let us take a look and provide more targeted advice.
