Aug 19th, 2024, 4:18pm
problem with current mirror (Read 2696 times)
icekalt
Aalen, Germany
Jul 24th, 2009, 7:34am
When i simulated the circuit below, the drain current of transistor M5 is not equal to 100uA. What is the problem here?
thx
raja.cedt
Re: problem with current mirror
Reply #1 - Jul 24th, 2009, 8:07am
hi,
  please check vds of M5..i think the problem is because of less common mode voltage.if you have less vds then please increase input common mode voltage.
Rajasekhar.
icekalt
Aalen, Germany
Reply #2 - Jul 24th, 2009, 8:35am
raja.cedt wrote on Jul 24th, 2009, 8:07am:
hi,
Rajasekhar.
hello,
Vds is 1.17687nV.
boe
Reply #3 - Jul 24th, 2009, 11:08am
icekalt wrote on Jul 24th, 2009, 8:35am:
hello,
Vds is 1.17687nV.
Then the transistor is not in saturation and therefor, will not act as current source.
BOE
raja.cedt
Reply #4 - Jul 25th, 2009, 1:08am
hi,
   so please increase vds of the tail transistor (just increase the common mode voltage)
rajasekhar.
