Sep 28th, 2024, 2:26pm
Fully Differential Folded Cascode OTA With SC-CMFB design HELP (Read 5404 times)
cdbular
Jul 31st, 2009, 12:53pm
I have designed a fully differential folded cascode OTA with SC-CMFB.
I have tested the circuit using a SC-CMFB network using Verilog-A macromodel switches. And the OTA seems to work very well.
When I replace the switches with transistors the clock injection is so bad that the CMFB voltage (which should be around 900mV) never is mantained at a fixed value and varies in a much wider range . The common mode open loop gain seems to be as large as the differential gain (~70dB) as well is the Unit gain Bandwidth (>125MHz).
I attached the images of the schematic and the simulations.
When using the MOS switches the CMFB voltage varies in a much wider range. As you can see in the simulation screenshots.
Schematic Screenshot
Transient simulation using Ideal Switches
Left: Diferential output, Rigth: VCMFB, Differential input: 300uV
Transient simulation using MOS Switches
wave
Re: Fully Differential Folded Cascode OTA With SC-CMFB design HELP
Reply #1 - Jul 31st, 2009, 6:07pm
I don't see the clock waveforms -- where is your Non-Overlapping clk generator?
raja.cedt
Reply #2 - Jul 31st, 2009, 8:03pm
hi,
  have you checked normal operation properly? because i don't think Charge Injection will give this much problem.... some times inadequate bandwidth in CMFB also troublesome..
Rajasekhar.
cdbular
Reply #3 - Aug 1st, 2009, 12:10pm
Hello, thanks for replying
Wave, I am generating non-overlaping clock phases with Vpulse sources in cadence.
Rajasekhar, What do you mean with normal operation? How should I check this?
How should I check if the CMFB bancwidth is correct?
Carlos Bula
HdrChopper
Reply #4 - Aug 2nd, 2009, 11:14am
cdbular wrote on Aug 1st, 2009, 12:10pm:
Hi Carlos,
One way to check the CMFB BW is to use Periodic STB analysis (Pstb). This tool allows you to analyize the stability of any loop that has two different periodic operating points, like the case of the SC CMFB you are showing.
Another simpler approach is just to apply a step to the input of your CMFB and see how it looks and what the settling time is. From there you can check what the BW is for such circuit.
Hope this helps.
Tosei
Keep it simple
Berti
Reply #5 - Aug 2nd, 2009, 11:54pm
Quote:
...never is mantained at a fixed value and varies in a much wider range .
The common-mode seems to settle, I don't see a big problem. But it looks like that you have inadequate CMFB bandwidth as Rajasekhar pointed out.
Cheers
cdbular
Reply #6 - Aug 3rd, 2009, 7:29am
In case that I have inadequate CMF bandwitdh, How should I correct this?
