Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 28
th
, 2024, 2:26pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Pass-gate behavior when switched off
Previous topic
Next topic
Pass-gate behavior when switched off (Read 3969 times)
skapc66
Aug 03
rd
, 2009, 6:16am
With reference to attached picture
If I connet a voltage generator (V1) to a pass gate switched off (V2>V1) I see that the other passgate output Vx follows the input (example being V2=2V, I get Vout=1.3V if V1=1.7V and Vout=1.5V if V1=2V). Cannot understand why. Could you help?
IP Logged
raja.cedt
Re: Pass-gate behavior when switched off
Reply #1 -
Aug 3
rd
, 2009, 6:47am
hi,
check the ckt properly, i think you pmos is still passing signal so please check wether you have connected proper vdd to that or not?
Rajasekhar.
IP Logged
skapc66
Reply #2 -
Aug 3
rd
, 2009, 6:53am
I checked once more, all the connections are as in the picture I attached.
Rgds
IP Logged
salty
Austin, Tx
Reply #3 -
Aug 3
rd
, 2009, 8:30am
Do you have anything tied to Vx? Other that the 2 transistors?
Try this if not, put a 1MEG pulldown and see what it does.
IP Logged
skapc66
Reply #4 -
Aug 5
th
, 2009, 11:36pm
I had an inverter input connected to Vx, but the Vx value remains the same even if I disconnect it.
Rgds
IP Logged
raja.cedt
Reply #5 -
Aug 6
th
, 2009, 12:08am
hi skapc66,
what i feel you don't see any difference in the voltage magnitude..but i am sure you could see the delay...what you do is increase the inverter size...now you feel the difference.
thanks,
rajasekhar.
IP Logged
salty
Austin, Tx
Reply #6 -
Aug 6
th
, 2009, 8:05am
Is this from a transient sim or DC sim?
IP Logged
raja.cedt
Reply #7 -
Aug 6
th
, 2009, 10:16am
hi,
ya do tran only for all digital ckts.......
thanks,
Rajasekhar.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
