Jul 16th, 2024, 8:28pm
Questions about Switched capacitor circuits simulation with PSS+PNOIS (Read 2603 times)
lunren
Asia
Aug 05th, 2009, 2:46pm
Today I simulated my swiched capacitor circuit (sample and hold) with pss+pnoise. In the simulation, the switched capacitor common mode feedback circuit was replaced by a ideal one. I am wondering how to use the real swiched capacitor CMFB in my simulation?
Why I was confused by this? Because SC-CMFB will take some time to settle down. I am not sure if I use the real SC-CMFB, the simulation results is culculated at correct DC operating point or not. Hope someone can give me some hints about this.
Lunren
Lunren
HdrChopper
Re: Questions about Switched capacitor circuits simulation with PSS+PNOIS
Reply #1 - Aug 5th, 2009, 5:50pm
You SHOULD use the real CMFB circuit. PSS takes care of looking for the steady state value, meaning that it will iterate as much as it needs until it finds a stable periodic operating point.
Only after finding such point  it will start pnoise analysis.
Hope this helps
Tosei
Keep it simple
lunren
Asia
Reply #2 - Aug 5th, 2009, 6:15pm
So that means I do not need to set tstart=50u, for example (assuming cmfb settles down after 50us)?
Lunren
