Sep 28th, 2024, 2:24pm
help me to evaluate my simulation result (Read 563 times)
icekalt
Aalen, Germany
Aug 10th, 2009, 3:44am
Hello everyone,
Please see my output waveform of my comparator in attachment. The comparator should make decision when the clock (Vclk) is low. Vp and Vn are the input of my comparator.Vout- is the output of my comparator. If you see the waveform, the output will be 3.3 although Vn is greater than Vp at certain time. For example, at 224.959ns, Vp is greater than Vn, but the comparator is in reset(no decison) in this time and the Vout- is appr. 1.7 V and it is fine. But when the clock is low, instead of comparing the present value of Vn and Vp, it compares the previous value of Vn and Vp that is at 224.959ns. Is this result ok or no? Is this what we called latency problem?
Thx in advanced
mikro
Re: help me to evaluate my simulation result
Reply #1 - Aug 18th, 2009, 6:50am
if i were u, i will recheck the logic vs schematic .
if u wanna compare the inputs, which were present shortly before low-active, it is fine.
if u wanna compare the inputs, which are present during low-active, it is not fine.
Berti
Reply #2 - Aug 18th, 2009, 10:42pm
Latency problem? Never heard!
To me it looks more like that your comparator has a large hysteresis. Reasons might be incomplete reset or bad settling of reference voltages.
Cheers
