Sep 28th, 2024, 4:17pm
A question about device noise simulation of sigma-delta modulators (Read 2380 times)
alixluohao
Aug 10th, 2009, 8:10pm
Today I simulated the device noise of my swiched-capacitor sigma-delta modulator with the method using a ideal S/H to close the loop, as the designer's guide "Device Noise Simulation of sigma-delta modulators" said. The ideal S/H is implemented by Verilog-A as follows:
module sah_ideal(vin, vout, vclk);
input vin, vclk;
electrical vin, vout, vclk;
parameter real vtrans_clk = 1;
real vout_val;
   analog begin
   @(cross(V(clk) - vtrans_clk, 1.0))
           vout_val = V(vin);
    V(vout) <+ vout_val;
The tran simulation may be OK, but when implementing a PSS simulation, the "vout_val" is refered as a hidden state and the PSS simulation is terminated. How to eliminate the hidden state so as to apply the S/H to the device noise simulation? Cry
Thanks!
LUO
currant
Re: A question about device noise simulation of sigma-delta modulators
Reply #1 - Aug 10th, 2009, 10:57pm
 Look this article about hidden-state free SH
http://www.designers-guide.org/Analysis/hidden-state.pdf
 As I understand, it is impossible to simulate sigma-delta modulator by periodic analysis, because the output of modulator is not periodic, but chaotic. I've read about this in Spectre RF docs.
Best regards.
HdrChopper
Reply #2 - Aug 11th, 2009, 5:37pm
Hi LUO,
Usually the noise performance of a sigma delta modulator is dominated by the first integrator. Try then to analyze the first integrator noise with PSS. In this case PSS will work and you will get a good idea of what your main input noise source will look like.
Tosei
Keep it simple
alixluohao
Reply #3 - Aug 11th, 2009, 10:59pm
Thank you for your suggestions. I will read the pdf "Hidden state in specreRF" and pay attention to the noise of the first intergrator. Smiley
