Oct 17th, 2026, 5:15am
Capturing wave forms from ocean/skill (Read 4729 times)
gzatorre
Aug 11th, 2009, 12:15am
Hi every body,
I am developing an ocean script that plots some data and I want to capture the wave form window automatically. To do it I am trying to use:
    window=newWindow()
    currentWindow(window)
    plot( Vout ?expr '( "Vout" ) )
    system(strcat("xwd -out " out_file " -name " window ))
It does not work because the window variable is "window type". In fact, if you write this in ocean:
  strcat("hola" window )
You will have this
  *Error* strcat: argument #2 should be either a string or a symbol (type template = "S") - window:2
Is there any way to convert a "window type" variable to "string type"? Even more, is there any other way to capture the wave form window?
Thank you in advance
Best regards
Guillermo
« Last Edit: Aug 11th, 2009, 2:44am by gzatorre »
Re: Capturing wave forms from ocean/skill
Reply #1 - Aug 15th, 2009, 5:52am
Well, you could get the window ID as a string, but it's not going to help you because it is not the X window ID. For example:
window->windowNum will return the window number.
The best solution is to make sure you're using Wavescan rather than AWD as your waveform tool. Then you can use:
hardCopyOptions(?hcOutputFile "waveform.png")
hardCopy()
If the filename has the suffix .png, .tif, .tiff or .bmp then a bitmap image will get created from the window contents (the same as File->Save As Image menu).
