Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 28
th
, 2024, 2:30pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Input common mode in differential amplifier
Previous topic
Next topic
Input common mode in differential amplifier (Read 1901 times)
giri_lp
Bangalore
Aug 13
th
, 2009, 6:21am
How do we have to understand the Vin CM in a differential amplifier? Is that the offset from 0 or it is DC CM or AC CM of the signal? Please explain this.
IP Logged
raja.cedt
Re: Input common mode in differential amplifier
Reply #1 -
Aug 16
th
, 2009, 10:36pm
hi,
i didn't understand your question properly..but generally opamp input they divide into common mode (dc) +differential mode (ac)....there is no question offset here.........
Rajasekhar.
IP Logged
aamar
Reply #2 -
Aug 17
th
, 2009, 12:31am
It is the in phase part of the 2 input signals either it is DC or AC. Normally it should be a DC signal in order to keep the operating points of the devices at a fixed point but it can contain also an AC component which has to be attenuated by the amplifier itself. The ability of attenuating the AC common mode signal at the inputs is the CMRR of the differential amplifier.
Best regards,
aamar
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
