Aug 16th, 2024, 10:17am
VCO phase noise variation with capbank (Read 2558 times)
Visjnoe
Aug 13th, 2009, 11:05am
Dear all,
I'm evaluating a 1.8GHz VCO with a 4bit capacitor bank for coarse frequency tuning. Typically, for a given frequency channel, the PLL that includes this VCO can obtain lock for three neighbouring capacitor bank settings i, i+1 and i+2.
I notice quite a significant phase noise variation (~ +/2 dB) between the lowest (i) and highest band (i+2) for each frequency channel.
I know that the VCO phase noise varies in general versus this capacitor bank setting since it influences the Q of the tank, but normally the Q of the tank will not vary a lot for neighbouring bank settings (differing only in 1 LSB)....
Any insights on the mechanism causing this variation are welcome.
scv
California, USA
Re: VCO phase noise variation with capbank
Reply #1 - Aug 13th, 2009, 4:06pm
Are these bits binary-weighted? What's the difference in Kvco for each bit choice? I would assume that higher Kvco's would translate into more phase noise since noise voltages would modulate the varactor capacitance by a greater extent.
Visjnoe
Reply #2 - Aug 13th, 2009, 11:47pm
The bits are indeed binary weighted. I see the large variation between setttings differing in 1-2LSB. Difference in Kvco also came to my mind, I'm investigating this at the moment.
