Oct 25th, 2024, 4:25pm
Quantify Amplifier Linearity: Is there a definition of linearity? (Read 2533 times)
Dave OB
Aug 24th, 2009, 2:54am
I'm trying to quantify the linearity of Gain for an amplifier design and compare it against another.
I'm currently calculating the maximum deviation of the output from linear as a percentage of the maximum output voltage swing.
Does this sound reasonable? Or is there an better definition for this value.
Thanks all
Dave.
raja.cedt
Re: Quantify Amplifier Linearity: Is there a definition of linearity?
Reply #1 - Aug 24th, 2009, 5:11am
refer any RF book ..you will see terms like IIP,1-dB comression point....
rajasekhar
Dave OB
Reply #2 - Aug 24th, 2009, 7:56am
Thanks.
sos
Reply #3 - Aug 26th, 2009, 1:17pm
Dave OB wrote on Aug 24th, 2009, 2:54am:
Thanks all
Dave.
Some context would help in making a useful reply. There are loads of ways to measure linearity, depending on what you're interested in. If your signals are large, your description makes sense. If you have a small signal that moves around to different dc levels, you might want an entirely different definition.
Steve
Sumit Adhikari
Reply #4 - Aug 28th, 2009, 12:14am
Do a FFT on your output. See at what level down your harmonics are.
Sumit
