Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 28
th
, 2024, 12:18pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› How do you size short channel transistors
Previous topic
Next topic
How do you size short channel transistors (Read 1773 times)
kidman
Aug 28
th
, 2009, 7:26am
I know that there is the gm/id method and I do use it to size the transistors. But the gm/id is a relatively new methodology so I want to know if there are other methods that designers use to design modern short channel transistors.
IP Logged
Re: How do you size short channel transistors
Reply #1 -
Aug 30
th
, 2009, 7:00pm
depends on what you are trying to do with the transistor. I think you need to be a lot more specific about what you are trying to do in order to get a meaningful answer
IP Logged
kidman
Reply #2 -
Sep 2
nd
, 2009, 9:13pm
my question is how do you determine the exact size of the transistor NOT what is your approach for sizing transistors (for example large L for high gian and so)
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
