Jul 21st, 2024, 8:23am
A question of the input referred noise (Read 1611 times)
alixluohao
Aug 31st, 2009, 4:59am
Hi
when reading the paper "Device Noise Simulation of Delta-Sigma Modulators", Manolis Terrovitis and Ken Kundert, www.desigers-guide.org/Analysis, I feel confused about the conclusion "The input referred noise of the open loop system is equal to that of the close loop system with feedback gain equal to one(or any other noiseless feedback)", who can give me a simple explanation if you have read this paper.
Thanks!
LUO
MarcoC
Cesena, Italy
Re: A question of the input referred noise
Reply #1 - Sep 8th, 2009, 2:02am
Hi alixluohao,
I didn't read the paper you cited but I can try to help you.
The input referred noise is the same in both cases - i.e. open loop and closed loop- because - let me say-  the global "transfer function" is different.
The closed loop is able to reduce the output noise but it changes also the gain in the same matter, so the input referred noise is the same.
My considerations are taken on a generic system but they should be applied also for delta-sigma.
I hope to be helpfull.
Bye,
MarcoC
View Profile MarcoC   IP Logged
