Sep 28th, 2024, 12:26am
Accuracy device foundry models with temperature (Read 2472 times)
Visjnoe
Aug 31st, 2009, 11:01am
Dear all,
At the moment, I'm measuring a circuit which shows faulty behavior at about 70deg. This circuit has been simulated uptil 125deg.
However, I can reproduce the faulty behavior by putting the temperature (in simulation) to 240deg. This makes me think there's a modeling error in some of the foundry device models...
Does anybody have experience with foundry modeling errors that result in such a large deviation between simulation/measurement, especially over temperature?
solidstate
Munich, Germany
Re: Accuracy device foundry models with temperature
Reply #1 - Aug 31st, 2009, 12:34pm
What kind of faulty behavior do you observe? What kind of circuit is this? Which process? Which foundry? It's likely that the error mechanism has a different tipping point for different process corners, or that the presence of device mismatch anticipates the onset..
Visjnoe
Reply #2 - Sep 1st, 2009, 12:13am
Maybe the intention of my question was a bit unclear. I do not want to discuss my specific case in depth, I just wanted to know if other people have encountered similar (or minor) discrepancies between simulation and measurement over temperature (for any given circuit).
Reply #3 - Sep 8th, 2009, 12:47am
Hi Visjone,
Most foundries provide SPICE models which fit the measurement data from -40 degC to 125 degC. I have never designed any circuitry that runs as high as 240 degC. Are you sure the SPICE model covers so high temperature?
Yawei
