If you use (say) the vsource in analogLib for your supply, then there is a parameter "Display noise parameters" which you can check. Then select Noise/Frequency Points as the Noise Entry Method and specify the number of noise/freq pairs you want. If using the older vdc source, you can just directly enter the number of noise/freq pairs you want.
Then enter the noise values in V^2/Hz for a set of frequencies.
