Dec 14th, 2025, 2:14am
discipline phase problem (Read 4589 times)
bandpass
Sep 08th, 2009, 5:50am
I use the model from kundert's paper, which declare the discipline phase, but when I simulate in Hspice, it's error. The error information is:Discipline compatibility at 'clkin': disciplines 'electrical' and 'phase' are incompatible.
I add the following three lines to disciplines.h
discipline phase
potential Angle;
enddiscipline
The veriloga module is:
`include "disciplines.h"
`include "constants.h"
//`include "phase.vams" // from Listing 2, includes disciplines.vams.
module divider(in, out);
input in; output out;
phase in, out;
parameter real ratio = 1 from (0:inf); // divide ratio
parameter real n = 0 from [0:inf); // white output phase noise (rads2/Hz)
parameter real fc = 0 from [0:inf); // flicker noise corner frequency (Hz)
analog begin
Theta(out) <+ Theta(in) / ratio;
Theta(out) <+ white_noise(n, "wpn") + flicker_noise(n*fc, 1, "fpn");
Re: discipline phase problem
Reply #1 - Sep 8th, 2009, 11:06am
The problem is probably due to what you are connecting to the divider. Apparently you are trying to connect an electrical component to a phase port.
bandpass
Reply #2 - Sep 9th, 2009, 5:57am
Ken Kundert wrote on Sep 8th, 2009, 11:06am:
Thanks for your reply. I still have some questions about the simulation of  phase-domain model of PLL. The models are from your paper. The question are:
(1)As you know, when we do AC simulation, we should specify the stimulate source for ac, but as your model metioned, the port are phase type, which cannot  be descibe by V** I**. how can I describe the phase source in netlist?
(2) In your mode, the top netlist mode is pll.va, which has no input source, just use the oscillator as input. when we simulate the testbench, the PLL just has one phase output port, has no input port, so the AC simulation will not take effect.
What's your suggestion? thank you very much
The attachment is the Hspice testbench of PLL phase domain model. The top netlist is as follows:
***phase domain simulation
.TEMP 25.0
.OPTION
*+    ARTIST=2
+    INGOLD=2
+    MEASOUT=1
+    PARHIER=LOCAL
*+    PSF=2
*.options probe
+ post=1
+ delmax=1e-10
.hdl "oscillator.va"
.hdl "divider.va"
.hdl "phaseDetector.va"
.hdl "pll.va"
.hdl "vco.va"
.hdl "loopFilter.va"
xpll out pll
.AC DEC 10 1 1MEG
v1 clkin 0  AC 1 *PULSE 0 1.2 0 1e-9 1e-9 9e-9 20e-9
.end
Reply #3 - Sep 9th, 2009, 1:11pm
You would create a phase source using Verilog-A.
Reply #4 - Sep 14th, 2009, 6:16am
bandpass wrote on Sep 9th, 2009, 5:57am:
[color=#0000ff]
Perhaps you knew this, but instead of V, the potential access function for discipline phase is Theta; you haven't declared the flow nature, which you would need to be able to access the flow.
