Hi Rich:
Thanks for your suggestion.
When I said data, I meant the output of the baseband. As you can see from my first post, the baseband I meant includes data filter and slicer.
I like your idea of header detection. The limitation is that the receiver will work only with the predefined header, unless the receiver is programmable.
I prefer more generic analog squelch circuit, which looks at the RSSI output and decides if there is anything higher than noise floor. But due to the random variation at RSSI output and front end noise, it seems require some onchip calibration to record the noise floor. I am trying to see if there is any existing product or publication on this topic.
Thanks.
XF
biff44 wrote on Sep 14th, 2009, 7:29am:You said analog baseband, but now are talking about data. If you are sending data, the standard way to stop what you are seeing is to use a header that is recognizable by your receiver. No header...no output data.
If you are sending something like video, you might be able to look for the big dynamic range (synch pulse), and squelch if you do not see it.
Rich
Maguffin Microwave LLC
