subgold
hi all,
i have a confusion about noise summary of spectre.
i have an opamp used in a closed-loop. when i change the feedback factor (the system is still absolutely stable), and resize some transistors (only in the output stage), the noise at the output node has increased (the white noise).
the noise summary shows that, now some current sources in the bias network become the main noise contributors, whose white noise has increased significantly. (before the change, the main noise contributors are the input transistor, which is as expected)
to me this noise summary is really confusing and should not be the case, because i checked the dc operating point of those transistors, and they remain exactly the same. (of course they should remain same because they are just in the bias network). also, this shouldn't have something to do with the change of the system bandwidth, because i only check the spot white noise at one certain frequency.
so ultimately what does this noise summary tell me? how can i reduce the noise then?
