Jan 23rd, 2026, 6:07pm
How to determine SNR, SNDR and SFDR of 8-bit ADC (Read 6356 times)
icekalt
Aalen, Germany
Sep 11th, 2009, 1:41am
hello,
I am currently measuring the dynamic perfomance of my ADC. What is really annoying me is i cannot get the spectrum or even the output of DAC. When i connect my ADC to a ideal DAC and simulate them, i got a constant value of output of DAC instead of a sinusoidal signal. Can anyone help me on this?
Re: How to determine SNR, SNDR and SFDR of 8-bit ADC
Reply #1 - Sep 11th, 2009, 2:34am
Nobody can help you without details like schematic, simulation setup, tools, stimulus, and so on.
icekalt
Aalen, Germany
Reply #2 - Sep 11th, 2009, 4:53am
ywguo wrote on Sep 11th, 2009, 2:34am:
Sorry for the vague question. I' simulating my ADC in LTSpice and now i don't know how to determine the dynamic perfomance of it. I have done static performance and the result is good where all codes are presents and monotonous. I have just found a matlab code to convert the the .raw waveform and i have successfully convert it and read it in matlab. The problem is i don't know whether i should take the output waveform directly from my ADC or should i connect my ADC into an ideal DAC then use the output of DAC in matlab. Another issues is i need a matlab code where i can use directly. i really never use matlab before. Help is really appreciated
Reply #3 - Sep 12th, 2009, 1:11am
Hi icekalt,
One point you must have in mind, what we expect at the ADC output is discrete signal.  So be careful don't make FFT to the continuous waveform. I don't know LTSpice. It seems to be a SPICE like simulator. Now that you simulate with LTSpice, print every sample of the ADC output. If you don't have any other tool at hand, you have to write a matlab program to process the printed results.
Try to print the ADC output with the following command in SPICE file.
.tran step start stop  $ set step = sample time
.print D_7 D_6 D_5 D_4 D_3 D_2 D_1 D_0 $ print the voltages of ADC output
Yawei
