Sep 28th, 2024, 4:16am
65nm CMOS MAx Operating Frequency (Read 4624 times)
AnalogGR
Sep 11th, 2009, 5:24am
is any rule of thumb where you can get the max operating frequency and the max data rate of each process?
For example 0.25μm CMOS can operate at 2.5GHz or transfer data at 5Gbps
George Best
Re: 65nm CMOS MAx Operating Frequency
Reply #1 - Sep 11th, 2009, 4:47pm
Way too general a question - totally depends upon the nature of the specific circuit being designed, the driving and loading environment, etc.
raja.cedt
Reply #2 - Sep 12th, 2009, 6:45am
hi,
  i feel it mainly depends on the ft of the technology.
Rajasekhar.
kidman
Reply #3 - Sep 13th, 2009, 1:32am
I agree with raja. Plot the ft of the technology. There's a rule of thumb that the max unity gain freq you can get out of a technology is ft/10.
Check the 3rd and 4th lecture in this link
http://bwrc.eecs.berkeley.edu/classes/icdesign/ee240_s09/
Berti
Reply #4 - Sep 15th, 2009, 2:44am
Generally ft is probably a good indicator, but in reality the maximum speed of your digital gates depends on their propagation delay which is e.g. a function of the threshold voltage.
Depending on the technologies process option a 65nm CMOS digital gate might therefore not be much faster than in 130nm (but lower leakage).
Reply #5 - Sep 19th, 2009, 4:11pm
minor detail - Ft is a great indication of the theoretical limitations of the transistor - and not much else - I dont know of any real world design that operates near the Ft of the transistor, and the GBW characteristics are going to be heavily dependent on the applications circuit and loading around it.
