Sep 27th, 2024, 8:17pm
problems about filter solution v8.1 software (Read 2465 times)
baohulu
china
Sep 11th, 2009, 11:49pm
hi, all
I use filter solution8.1 to synthesize a chebyshev II filter, which is in digital domain, for example, passband 1Hz, sampling clock 64Hz, and stopband ratio 1.5, then see its frequency response. as I know, its spectrum should be from -32Hz to +32Hz, when repeat it. however, in this software, its spectrum is from 0 to 64Hz, why?
buddypoor
Bremen, Germany
Re: problems about filter solution v8.1 software
Reply #1 - Sep 12th, 2009, 8:22am
Because the program reflects reality !
There are no negative frequencies in reality !
It is only a mathematical "trick" to use neg. frequencies during formulation and calculation of the fourier transform (based on EULERīs formulas).
As a result, you have 2 alternatives: spectrum from -x to +x with amplitudes A or from 0 to 2x with amplitudes 2A.
Berti
Reply #2 - Sep 15th, 2009, 2:40am
SSB spectrum is the frequency from 0 to +x with 2x the amplitude (0..32Hz). Why should the frequency go up to 2x? Do I miss something?
Cheers
buddypoor
Bremen, Germany
Reply #3 - Sep 15th, 2009, 2:55am
Berti wrote on Sep 15th, 2009, 2:40am:
Cheers
No, Berti, you didnīt miss something.
But I was wrong, sorry. It was a mixture of typing/thinking error.
Of course, the spectrum goes only up to +x.
Thanks, regards
