Aug 24th, 2024, 11:24pm
Pages: 1 2
What is drawback to use minimum-sized transistors for analog switch? (Read 19285 times)
tony_taoyh
Sep 16th, 2009, 4:11am
To reduce the charge injection and clock feed-through for analog switch,
minimum sized device can be used if Ron is not a issue.
What is the drawback to use the minimum sized device?
Thanks a lot.
Berti
Re: What is drawback to use minimum-sized transistors for analog switch?
Reply #1 - Sep 16th, 2009, 4:16am
If settling (Ron, also taking into account process variations) is still ok I don't see an issue.
Other opinions?
raja.cedt
Reply #2 - Sep 17th, 2009, 12:13am
hi,
   what is the meaning of no issue Ron? means if you have any value is it ok  or even though it changes with time or PVT? because if you put smaller switch you will see larger PVT variations
Rajasekhar.
Mayank
Reply #3 - Sep 17th, 2009, 1:16am
hi,
     minimum sized device(or length) will introduce more flicker noise....That might cause problems.
regards,
Mayank.
raja.cedt
Reply #4 - Sep 17th, 2009, 3:53am
hi,
   ya,thats true but generally in high speed sample and hold circuits flicker noise will not come due to its low frequency spectrum. By the where you are using switch?
Rajasekhar.
RobG
Bozeman, MT
Reply #5 - Sep 17th, 2009, 8:39am
I think it is one of those rules of thumb that has been followed so long nobody can remember why. The reason I was given was that you are pushing the edge of the process, which might give some leakage when off, but I'm not sure how true this is. I used min gate lengths for my last design.
You may already know this, but contrary to intuition, differential charge injection is minimized with minimal switches since you are subtracting the mismatch, not averaging the mismatch. So that is another reason to use as small as possible switches.
rg
raja.cedt
Reply #6 - Sep 17th, 2009, 10:05pm
hi rg,
       i didn't understand last para in your post (average mismatch....etc)...if you decrease the device size all secondary effects will decrease vth and leakage will increase. And i feel differential configuration would be help full to cancel this one.
Rajasekhar.
Berti
Reply #7 - Sep 18th, 2009, 12:11am
rg, I don't understand your post, too. What "rules of thumb" are you talking about?
Rajasehkhar, "decrease the device size" means decreasing L or W? Why decreases vth with smaller W?
Cheers
tony_taoyh
Reply #8 - Sep 18th, 2009, 12:54am
Thanks a lot. Guys.
With short channel effect, the Vth is roll-off when L is reduced.
raja.cedt
Reply #9 - Sep 18th, 2009, 1:30am
hi berthi,
               i am sorry, type mistake decreasing w will increase Vth due narrow width effect
Rajasekhar.
Berti
Reply #10 - Sep 18th, 2009, 5:10am
Rajasekhar, sorry, I think you original post was generally correct (in fact I think it depends on the technology, but I am not so familiar with this topic).
rajdeep
UK
Reply #11 - Sep 18th, 2009, 7:29am
I also think it is due to more PVT variation at min length. The models that we use for simulaiton may not be that accurate at that limit. It is always safe to use 4*Lmin if possible. So, if speed is ok and feedthrough problem doesnt increase much I'll tend to use longer length just to be in the safer side.
Not sure whether the switch will be more leaky or not in  OFF state when using Lmin for the same W/L ratio...... Lips Sealed
Rajdeep
RobG
Bozeman, MT
Reply #12 - Sep 18th, 2009, 8:08am
Berti wrote on Sep 18th, 2009, 12:11am:
I was speaking about the "rule of thumb" that says not to use minimum sized devices for switches. Throughout my career I've heard it from many people to use channel lengths a bit longer than minimum, but nobody ever knew exactly why.
As dimensions decrease the Vt starts changing pretty rapidly with small ΔL and ΔW implying more mismatch potential. Perhaps that is a practical consideration.
RobG
Bozeman, MT
Reply #13 - Sep 18th, 2009, 8:30am
raja.cedt wrote on Sep 17th, 2009, 10:05pm:
hi rg,
Guess I'm confusing everyone...
I was talking talking about charge injection in differential circuits. As you know, if it is matched the injected charge is common mode and not an issue.
On the other hand, if there is a mismatch in the injected charge you will get an error signal. It follows that you would like to match the charge injections as well as possible. Most people assume that larger switches will match better, but this is not true for matching charge injection. The matching improves as sqrt(area), but the amount of charge increase proportional to area.
Reply #14 - Sep 19th, 2009, 4:17pm
Common mode effects are greatly reduced, agreed, but not eliminated. Don't get into binary thinking Wink with analog systems.
From my experience, min geometry for switches is generally the way to go. For everything else, the matching concerns and PVT variance come out to bite you.
Pages: 1 2
