bluestatic
we are trying to follow the spectre RF noise-aware PLL sim flow. Using MMSIM71 and IC5141(with latest hotfix), and the PLL is running at 2.5GHz.
It goes well at the beginning, the divider ,CP and VCOmodel was extracted sucessfully, though we can not view it since the model was encrypted. We don't see much problem since it is a general PLL structure and the flow very straightfoward too. We set the ChargPump load voltage (Vload) to 0.45~0.75.
The transient simulation also goes well at first, untill the chargepump load voltage gradually reached 0.45V, ie, the lower boundary of the voltage range we set previouse in CP model extraction. Now the simulation become very slow, the simulation step is 0.01 fs. It takes 6 hours to simulate 3us. And after the simulation run to 60us, the result psf data has become 65G bytes, which is not possible to be handled by wavescan.
Can anyone please tell me what's happening here? Thanks a lot
