Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 19
th
, 2024, 9:52am
Home
Help
Search
Login
Register
PM to admin
Measurements
Other Measurements
› how to generate a negative voltage during test
Previous topic
Next topic
how to generate a negative voltage during test (Read 71 times)
trashbox
Sep 20
th
, 2009, 7:58pm
I need to add a negative voltage on the PCB for my circuit, the average output current is about 80mA. Except the charge pump chip, how can I realize a negative voltage with simple method?
Thanks in advance!
Trashbox
IP Logged
Re: how to generate a negative voltage during test
Reply #1 -
Jan 8
th
, 2010, 1:49pm
a separate negative power supply
an oscillator generator and an isolation transformer
a capacitive charge pump
A solar cell and a bright light (just kidding)
IP Logged
love_analog
Reply #2 -
Apr 20
th
, 2010, 8:12am
You can easily use a negative buck boost. This way it is also easy to change the voltage later on (by changing duty cycle)
loveanalog.blogspot.com
The Power of Analog
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
»» Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
