Sep 28th, 2024, 10:19am
Charge amplifier (Read 1647 times)
arduino
Charge amplifier
Sep 22nd, 2009, 3:15am
hello...i have a problem with my charge amplifier....in particular with the N-MOS.
when i increment the dc current the Vout go to 3.8V while Vin decrement.
someone can help me to understood it??? Cry
thanks
mimic
Re: Charge amplifier
Reply #1 - Sep 22nd, 2009, 11:36pm
Does this circuit settle to a stable operating point when there is no input signal applied? Generally your first steps should be to design your DC points for this scenario.
I see a common source stage + a soure follower.. what I cannot understand is how the feedback (capacitor + nmos) guarantees the closed loop gain. Is that path ok?
Certainly the fact that you see 3.8V at output while your Vdd is 3.3 point to an issue linked to bad DC points.
Reply #2 - Sep 23rd, 2009, 3:00am
Hi arduino,
Have you checked the voltage at drain of M8, which is also the gate of M9?
I guess it is not a proper value because the common source amplifier composed of M8 and an ideal current source. Try to replace it with a resistor or a NMOS loading.
Yawei
