Hi Vivek,
I'm hoping you've found an answer by now, but essentially parameters are a way to set the value of a parameter on a specific instance - rather than variables, which are "global variables". If you use Window->Assistants->Parameters, Sweeps and Corners Setup (with the schematic displayed in the window) you can click on components in the schematic, and define the parameters.
This is covered pretty well in the ADE XL Documentation - so I suggest you read up on that too.
