Oct 21st, 2024, 9:14am
low via resistance in tsmc013 (Read 2706 times)
Vladislav D
The Netherlands
Oct 01st, 2009, 2:43am
Hello colleagues,
I did the extraction of the via M1-M2 in tsmc 0.13 and got really small resistance. It is about only 1Ohm. Do you think if it can be true or rsistance should be higher? Tnank you
Re: low via resistance in tsmc013
Reply #1 - Oct 2nd, 2009, 9:52am
Via resistance in all processes changes a huge amount over foundry wafer lots from the exact same foundry and process.. If it is nominally 1 ohm, the expectation of it to change from 0.5 ohms to 2-5 ohms should be designed for.
Safe premise: Always use enough via connections that the resistance of the vias is not enough to affect the design.
Bottom Line: lots of vias in parallel
Vladislav D
The Netherlands
Reply #2 - Oct 4th, 2009, 12:53pm
Thank you for the answer. I just didn't expect that even the typical resistance could be so low.
Reply #3 - Oct 4th, 2009, 2:57pm
Low is a matter of perspective. To someone putting large currents in an IC, the resistance of the layer change has been very problematic.
Via interconnects have been an issue with high current power transistors, RF power amps,  H bridge motor drivers and other areas.
