Sep 28th, 2024, 12:14pm
Stability analysis of Automatic Amplitude control loop (Read 3770 times)
osc
Oct 06th, 2009, 8:31am
Hi
I am planning to design an oscillator with Analog amplitude control loop. The problem I face is that this loop by nature is very non-linear and difficult to check for stability. Stability problems lead to a phenomenon called squegging.
Can some one help with the simulation/analysis of such a loop.
buddypoor
Bremen, Germany
Re: Stability analysis of Automatic Amplitude control loop
Reply #1 - Oct 7th, 2009, 12:53am
osc wrote on Oct 6th, 2009, 8:31am:
Hi
There are some remarks to be made to your posting:
1.)  There are several different alternatives for amplitude control - and before analyzing such a loop your choice has to be made. Try to become familiar with these options (literature study).
2.) The loop must NOT be "very" non-linear. In contrary, it should be as linear as possible and as non-linear as necessary to do the job.
3.) Squegging is not a stability problem, but the normal behaviour of each control loop - as the result of the error signal which swings around a certain middle value.
4.) Question: Do you have chosen already the type of oscillator circuit?
osc
Reply #2 - Oct 7th, 2009, 7:16am
Thanks for your inputs..
I am checking for the literature at present ....
do you have any recommendations..
The problem I can think of with squegging is a very degraded phase noise performance and I an reffering to crystal oscillators(pierce)..
buddypoor
Bremen, Germany
Reply #3 - Oct 7th, 2009, 7:23am
osc wrote on Oct 7th, 2009, 7:16am:
This really depends on the oscillator circuitry. It makes absolutely no sense to speak of an amplitude control loop without knowing the circuitry to be controlled.
osc
Reply #4 - Oct 7th, 2009, 7:39am
I am reffering to crystal oscillator (pierce configuration)..
raja.cedt
Reply #5 - Oct 7th, 2009, 7:42am
hi,
   as above people explained you should decide oscillator architecture first. All these amplitude control and jitter are storngly depends on type oscilalator. Basically whats your application?
Rajasekhar.
