jojo wrote on Oct 10th, 2009, 12:26am:Dear all
I read some paper about sscg, two of them said "create periodical triangular modulation signal at the input node of the VCO", but them do not explain why use triangular wave. where can i find the reason? thanks.
Can you point out which references are those you are referring to?
I read some papers in the past before about this but do not remember the triangular modulation signal you are talking about
Best
Tosei
