Apr 28th, 2024, 10:04pm
How to feed 4 RF signals with phase relationship for mixer ? (Read 5102 times)
Tiger
Oct 12th, 2009, 12:15am
hi, all
I have met a problem when measuring a ssb-mixer:
I have to feed four signals(9GHz) with phase relationship (LOinIP,LOinIN,LOinQP, LOinQN ) for mixer(IC), and to ensure the relationship of the signals does not change when arriving at the pads of IC (the IC`s pads are connected by bondwires to PCB`s pads, and then to the SMA connectors through microstrip).
By using 90 & 180 degree Hybrids, we can generate the 4 signals from one signal source. Then, we use cables of good phase stability to transmit the four signals to the PCB`s SMA connectors.
However, we find the phase relationship of the hybrids`output are sensitive to their loads; by this I mean, if the load is exact 50om, the phase is 90 or 180 degree, while if the load is not 50om, the phase is not 90 or 180 degree either..Here comes my problem: from the SMA connector to the IC, the impedance is not exact 50 om, so the relationship of signals arriving at the IC`s pads is not what I want either..
I`d like to know your suggestions, and how you  feed 4 RF signals with phase relationship to your IC.
Many thanks!
Tiger
Re: How to feed 4 RF signals with phase relationship for mixer ?
Reply #1 - Oct 13th, 2009, 1:49am
truely hope someone can help me
thanks!
RFICDUDE
Reply #2 - Oct 13th, 2009, 11:38am
Well, the not so helpful answer is that we design the phase splitter on chip using frequency dividers and symmetrical layout techniques.
On a board or hybrid I would imagine that you may need a way to tweak the phase and amplitude balance of the LO signal right at the inputs of the IC. If you do not need wideband (relative to the LO frequency) operation then you could get away with tweaking a little attenuation and capacitance for phase right at the inputs, but I suspect you need something more versatile than that for your application.
Tiger
Reply #3 - Oct 13th, 2009, 6:48pm
Many thanks, RFICDUDE
Reply #4 - Nov 2nd, 2009, 10:59pm
Tiger wrote on Oct 12th, 2009, 12:15am:
Try to insert attenuators(e.g. 3dB) between Hybrid's output and DUT's input.
