Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Oct 21
st
, 2024, 1:27pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Low Jitter Clock Generation with a External Crystal
Previous topic
Next topic
Low Jitter Clock Generation with a External Crystal (Read 4177 times)
neoflash
Mixed-Signal
Designer
Oct 19
th
, 2009, 11:56am
Hi folks:
We are leaning to design a clock generator with a external crystal.
Pierce and Colpitts oscillator seems to dominate the design. Which type better suites our target and why?
Neo
Last Edit: Oct 20
th
, 2009, 9:02am by neoflash
IP Logged
Re: Low Jitter Clock Generation with a External Crystal
Reply #1 -
Oct 20
th
, 2009, 8:26pm
neoflash wrote
on Oct 19
th
, 2009, 11:56am:
Hi folks:
Neo
Neo, what is your target? It is vague to say design a clock generator.
What is the clock frequency?
Any requirement on phase noise or jitter?
How many pads are available?
IP Logged
raja.cedt
Reply #2 -
Oct 20
th
, 2009, 9:17pm
hi Neo,
if you are able to design colpits oscillator with your specifications then from many points of view it is the best one (like excellent phase noise, frequency stability..etc)
rajasekhar.
IP Logged
neoflash
Mixed-Signal
Designer
Reply #3 -
Oct 21
st
, 2009, 6:20am
We need a low jitter ~50MHz clock generator. Sub-picosecond is the target when applied with a 10MHz HPF.
Currently, the confusion is that the same device gm can not startup colpitts while having no problem with Pierce.
Two pads is possible.
IP Logged
neoflash
Mixed-Signal
Designer
Reply #4 -
Oct 21
st
, 2009, 12:24pm
I did some analysis and found that pierce and colpitts are exactly same in small signal.
More confused why Colpitts doesn't start while pierce always start easily.
IP Logged
Reply #5 -
Oct 21
st
, 2009, 5:49pm
there is a dialog here on the fourum about "quick starting crystal" oscillators and some simulation tricks - search for it, some useful things there, because High Q crystals often get messed up in simulation.
IP Logged
neoflash
Mixed-Signal
Designer
Reply #6 -
Oct 21
st
, 2009, 8:33pm
Just realized that body effect in Colpitts has to be removed. Otherwise, the complete small signal negative resistance change.
Stupid mistake and ignorance.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
