Jul 17th, 2024, 6:35am
LPF w/t variable cut off freqency (Read 1364 times)
sand_dolphin2
Japan
Oct 19th, 2009, 7:31pm
Plz help me by some kind advice!!
I want to make LPF w/t variable cut off freq.
The select signal is comming from logical.
i want to make smart code like bellow case like verilog-HDL.
//---- from code
logic [1:0] FREQSEL;
electrical in,out;
analog
begin
   if(FREQSEL == 2'b00)
    begin
     V(out)      <+ laplace_nd( V(in), { num0 }, {den0, den1_750k} );
   else if(FREQSEL == 2'b01)
    begin
     V(out)      <+ laplace_nd( V(in), { num0 }, {den0, den1_1_5M} );
   else //if(FREQSEL == 2'b10 or 11 or x)
    begin
     V(out)      <+ laplace_nd( V(in), { num0 }, {den0, den1_3_0M} );
//---- end code
I'd already know the laplace fanction can't set variable freq.
so,the compiler output Error log.
But, i want to make code simply like this for Digital designer like me Embarrassed
Plz give some advice!! Wink
See you soon
ciao Wink
boe
Re: LPF w/t variable cut off freqency
Reply #1 - Oct 22nd, 2009, 3:23am
sand_dolphin2,
According to sec. 4.5.15 in  the Verilog-AMS LRM (version 2.3.1, http://www.designers-guide.org/VerilogAMS/vams231.pdf) analog operators (such as laplace_xx) are not allowed inside if/case etc. statements (unless using constant expressions). Poles and zeros may not change either (cf. sec. 4.5.14).
One possiblity is to use 3 filtered internal signals: Code:
analog
begin
   V(out750k)	<+ laplace_nd( V(in), { num0 }, {den0, den1_750k} );
   V(out1M5)	<+ laplace_nd( V(in), { num0 }, {den0, den1_1_5M} );
   V(out3M)	<+ laplace_nd( V(in), { num0 }, {den0, den1_3_0M} );
	V(out) <+ V(out750k);
	V(out) <+ V(out1M5);
	V(out) <+ V(out3M);
This requires 3 internal signal nodes, so it may not be a very efficient solution.  And when switching, the signal will usually jump.
Of course, there are other options to solve this as well. Which solution is best depends on your requirements.
BOE
« Last Edit: Oct 22nd, 2009, 6:18am by boe »
sand_dolphin2
Japan
Reply #2 - Oct 22nd, 2009, 10:17pm
Dear BOE,
boe wrote on Oct 22nd, 2009, 3:23am:
sand_dolphin2,
BOE
Ohps! soo cool code!! Shocked
Thank you for your kindly explain and suggestion in always.
I can solve this by your code!!!  ;)
and our design not need to take care about switching influence.
See you soon if you like me!
bye for now. ciao  :)
Paul Floyd
France
Reply #3 - Oct 26th, 2009, 5:05am
Hi
laplace (like all analog operators), if used in conditional/loop blocks,  can only be used inside ones governed by genvars.
The arguments are "Constant expressions". This does not mean that variables are not allowed (4.5.14, see the note after table 4-20) or that there is a restriction where variables are used. It just means that the simulator must take the fist values.
So you should be able to write something like
  real den [0:1];
analog begin
    den[0] = den0;
      begin
       den[1] = den1_750k;
      begin
       den[1] = den1_1_5M;
      begin
       den[1] = den1_3_0M;
    V(out) <+ laplace_nd(V(in), {num0}, den);
Paul
« Last Edit: Oct 26th, 2009, 6:47am by Paul Floyd »
boe
Reply #4 - Oct 26th, 2009, 9:36am
Paul Floyd wrote on Oct 26th, 2009, 5:05am:
Hi
I assumed FREQSEL to be dynamic...
For your code to work FREQSEL has to be set to the desired value at the beginning of the simulation; and if this is OK, I would put that selection sequence into an initial_step statement.
BOE
Peruzzi
Reply #5 - Oct 26th, 2009, 2:41pm
All,
I responded to Sand Dolphin privately last week, seeking a short contract from his company, but with no luck ;-(
I did share the following hint with him and now I'm sharing it with others following this thread:
Sand Dolphin,
The problem you describe is straightforward to solve.  One solution is based upon differential equations in the form of state equations.  You must also use certain analog modeling principles which may be found in Ken Kundert's book "Designer's Guide to Verilog-AMS".
Cheers,
Robert Peruzzi
www.RPeruzzi.com
sand_dolphin2
Japan
Reply #6 - Oct 26th, 2009, 5:28pm
Dear BOE!!
Thank you for your cooperation in always Smiley
boe wrote on Oct 26th, 2009, 9:36am:
Hi
BOE
so, my designe should be changed FREQSEL dynamic. but there is no need to consider deeply the behavior of during changing this signals at this phase.
What kind of problem should i take care of the behavior of changing FREQSEL in this code ?
If you have some advice, plz let me know...
See you soon again
so,you are very high technical engineers i(we) think Shocked
chiao   Wink
« Last Edit: Oct 26th, 2009, 7:18pm by sand_dolphin2 »
boe
Reply #7 - Oct 29th, 2009, 10:51am
sand_dolphin2,
Paul Floyd's code limits you to one bandwidth per simulation run. If you need to change FREQSEL/the bandwidth during a simulation run, you can
1. use my "lazy" code from reply #1, which I created it within one or two minutes from yours (however it requires additional internal nodes as already mentioned), or
2. write your own filter model as Peruzzi suggested (requires less internal nodes so it should simulate better/faster, and also allows modeling the switching transition).
BOE
sand_dolphin2
Japan
Reply #8 - Oct 29th, 2009, 3:39pm
Dear BOE!!
Thank you so much for your kind.
boe wrote on Oct 29th, 2009, 10:51am:
sand_dolphin2,
BOE
i used "1" , so your #1 code. gooooooood. Wink
thanks ciao Smiley
btw how about your opinion about thread of
 AC analysis in verilog-ams
http://www.designers-guide.org/Forum/YaBB.pl?num=1237145096
i re opened this thread , and wait some comments from anybody.
if you have some advice, plz let me know.
best regards,
