Jul 17th, 2024, 6:19am
how to use noise_table function (Read 4652 times)
yaxazaa
Apr 14th, 2006, 7:04pm
Could someone explain more detail about how to use noise_table function?  My understanding is that the output should be defined as electrical, is that right?  For example, I have a table of phase noise verse frequency. The table should be:
phase_noise <= noise_table ({
1      -10
10   -50
1k   -89
1m -120
How do I call it in the top level? If I call the noise table, but try to conveter them to rad^2/hz, can someone tell me how to do it? Besides this, if I want the phase error which is "rad", how should I integrated them in time domain?
jbdavid
Re: how to use noise_table function
Reply #1 - Apr 21st, 2006, 1:48am
you will have an output node that needs to have the noise on it..
real phasenoise;
analog begin
phasenoise = noise_table( ....
V(out) <+ transition(in?vhi:vlo, 0, trf, trf) + phasenoise;
When NOT running a noise analysis phasenoise = 0 so contributes NOTHING to the output..
Jonathan
jbdavid
yaxazaa
Reply #2 - Apr 21st, 2006, 10:59pm
Actually what I am really interested is the phase noise affects  time domain information which is jitter. Detailly here is the steps but how to implement:
1. After read in an three columns' table of frequency vs phase noise, and slope of phase noise information, if my compiler doesn't have "scanf" function, how do I do line by line reading in and manuplation?
2. How do I integrate phase noise between certain frequencies in time domain? For example, do integration of ( (phase noise/10) * (frequency/fc)**phase_noise_slope) from frequency1 to frequency2, which fc is a constant.
3. After the step 2, then this will be phase uncertainty. Can I just add it to the time domain signal as some kind of jitter concept?
Thanks.
Reply #3 - Apr 25th, 2006, 5:19am
yaxazaa wrote on Apr 21st, 2006, 10:59pm:
The short answer is: you can't use noise_table to affect time domain information (jbdavid's post implies this, but says it differently).
A while ago, I found  a couple papers at the IEEEXplore web site on implementing 1/f-like noise in the time domain.
yaxazaa
Reply #4 - Apr 25th, 2006, 8:25pm
Could you post the paper here please?
Thanks.
neoflash
Mixed-Signal
Designer
Reply #5 - Oct 29th, 2009, 10:13am
yaxazaa wrote on Apr 14th, 2006, 7:04pm:
1      -10
10   -50
1k   -89
1m -120
Can we load the vector from a file in verilogA, instead of manually input them in the noise_table() function?
Reply #6 - Nov 2nd, 2009, 5:35am
