Jul 17th, 2024, 6:36am
What does -: mean? (Read 1402 times)
Mike_k
What does -: mean?
Oct 30th, 2009, 5:17pm
For example: bus_name[32-:8]
Re: What does -: mean?
Reply #1 - Nov 2nd, 2009, 5:45am
I thought it was a typo, but I do see that syntax in 1800-2005.
I think it was intended to allow you to grab a fixed-size slice of an array:
Quote:
The size of the part-select or slice must be constant, but the position can be variable. The syntax of Verilog is used.
int i = bitvec[j +: k]; // k must be constant.
So, in your case, I think [32-:8] is the slice starting at 32 and going down to get 8 bits, and thus would be the same as [32:25].  However, you could also have bus_name[x-:8] and sometimes x=32 and other times x=24, etc.
