Riad KACED
Swindon, UK
Hi Subgold,
I think there is a problem somewhere as this behavior does not really make sense from a physical point of view. There could be a problem with either you models cards or your Spectre version (very unlikely).
The standard deviation of the process itslef is usually broader than the mismatch as the latter is a local variation.
Best is to cross-check your model cards and share this problem with your PDK provider or with Cadence customer support.
I usually don't ask people to post their model cards as this is confidential information.
Cheers, Riad.
