Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Oct 21
st
, 2024, 9:07am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Comparing Comparators
Previous topic
Next topic
Comparing Comparators (Read 3083 times)
AnalogDE
Oct 26
th
, 2009, 10:25am
I'm trying to decide between the following two textbook comparators. One is a clocked comparator design from Razavi, the other is a non-clocked design from Baker.
What are the pros/cons of each architecture? I've listed what I can think of below.
Also, why in the Baker architecture is there a self-biased diff-amp in the output stage? Why not a regular diff-amp with NMOS current src tail like in the pre-amp stage?
Thanks!
IP Logged
AnalogDE
Re: Comparing Comparators
Reply #1 -
Oct 26
th
, 2009, 10:26am
Here is the Razavi clocked comparator:
IP Logged
HdrChopper
Reply #2 -
Oct 26
th
, 2009, 5:24pm
Hi jiesteve,
Bakker approach:
Pros: less offset and noise due to large input gain (the active loads can be made large and with low gm vs the latch devices which are typically large gm and small area). More gain also means less prop. delay (important for some comparators).
This design can easily be converted into a clock comparator if M12 is clocked (and a few additional switches are added to guaranteed output state).
Biasing could be a normal one (I guess self biasing for saving area)
Razavi approach
Cons: more offset (due to lack of large input voltage gain and large gm of latch devices). More prop delay due to smaller gain.
Bottom line:
More power --> better noise and offset. This trade off is unavoidable.
Hope this helps
Tosei
Keep it simple
IP Logged
raja.cedt
Reply #3 -
Oct 26
th
, 2009, 9:34pm
hi,
in addition to tosie comments, razaavi circuit have provision for reseting the output to some intermediate value and at the same time razaavi circuit has more gain, hence less regeneration time.
thanks,
rajasekhar.
IP Logged
spunky
Analog Designer
USA
Reply #4 -
Oct 28
th
, 2009, 12:53pm
For a high speed comparator, I think the pre-amp should have high gain but it is not necessary true for the following stages such as the latch or the intermediate stage. Because when the small difference is amplified by preamp it becomes a signal with relatively large amplitude, while the slew rate limitation prevails.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
