Jul 17th, 2024, 6:40am
Defining vector variable in veriloga (hspice simulator) (Read 623 times)
neoflash
Mixed-Signal
Designer
Oct 29th, 2009, 9:02am
Hello:
Some verilogA functions, such as noise_table, require a vector for content of the function.
For example, function noise_table(vector, noise_name).
The variable vector is required to be a two column vector, one is for frequency, the other is for noise power. Currently, I can only manually input the data points inside the noise_table function in below way:
noise_table({1,2,3,4},"name");
My question is that how I define this vector in a text file and load it into the verilogA model (inside hspice test bench).
Neo
« Last Edit: Oct 29th, 2009, 7:55pm by neoflash »
Re: Defining vector variable in veriloga (hspice simulator)
Reply #1 - Nov 2nd, 2009, 5:49am
Please see
http://www.designers-guide.org/Forum/YaBB.pl?num=1202431856/0#7
(Triple-posting your question! I'm guessing you forgot to do a search before posting this, and later found some old threads that were related (though didn't answer your question).)
neoflash
Mixed-Signal
Designer
Reply #2 - Nov 2nd, 2009, 6:05am
Geoffrey_Coram wrote on Nov 2nd, 2009, 5:49am:
Please see
Somehow like you guessed. But I do hope the replies notification can call people with related experience here.
Thanks for the reply.
