Oct 21st, 2024, 9:10am
Low - Noise Oscillator Design - Topology selection ?? (Read 2434 times)
Mayank
Nov 01st, 2009, 10:16pm
Hi everyone,
                  I have to design a low-noise voltage-controlled oscillator.
Specs :---
Oscillation Freq. = 1GHz
Voltage Supply -- 1.2
Noise requirements -- around -55dBc @10kHz or lower
Max. Current Consumption @ 1.2 supply <= 2.5mA.
Any Suggestions please ??
--mayank.
raja.cedt
Re: Low - Noise Oscillator Design - Topology selection ??
Reply #1 - Nov 1st, 2009, 10:28pm
hi mayank,
                i feel Phase noise spec seems very tough to achieve with ring oscillator so i feel LC is better but whats your Kvco or Tuning range.
rajasekhar.
Mayank
Reply #2 - Nov 1st, 2009, 10:44pm
      Kvco is not a problem...Can be adjusted in both Ring Osci...as well as LC[LC offers low Kvco's v easily]..LC easily gives these specs..but it crosses the Area Limit...can't use so much Si real estate  :(
Can't Ring Osci's satisfy these specs ??
--mayank.
raja.cedt
Reply #3 - Nov 1st, 2009, 10:51pm
hi,
   certainly you can do with ring oscillator but power you have to consider, so what i am suggesting is build some ring oscillator and vary power and check whether you are meeting power spec or not. I feel all these can be appreciated by simulation..not by any thing else
rajasekhar.
Mayank
Reply #4 - Nov 1st, 2009, 10:58pm
    I have already tried out different topologies in RO design...Not achieving results, That's why i brought this up to the forum.
      I have already tried out current-starved CCO, Differential CCO, CML topologies...All of them offer Low phase Noise at Lower Frquencies, but none of them are meeting my noise specs at around 1GHz....What i want to be sure is -- Are these topologies capable of giving such noise performance at given power levels &  i am not designing them correctly , Or I can rule out ROs and go for LC?
Just wanna be sure to rule out Ring Osci....
regards,
Mayank.
