Jul 17th, 2024, 8:27am
Module instantiation in topmodules? (Read 3100 times)
somisetty
Nov 06th, 2009, 5:26am
module inverter(vout, vde, vin, vss);inout vout;
electrical vout, vde, vin, vss;
input vde, vin, vss;
  analog begin
     vout_val = !(logic_in) ? vlogic_high : vlogic_low;
     V(vout) <+ transition( vout_val, tdel, trise, tfall);
module nand(vout, vde, vin1, vin2, vss);
inout vout;
electrical vout, vde, vin1, vin2, vss;
input vde, vin1, vin2, vss;
  analog begin
     vout_val = !(logic1 && logic2) ? vlogic_high : vlogic_low;
module toplevel(v1, v2, vout_final)
how to instantiate above two modules in this module?
Schematic is given below...
boe
Re: Module instantiation in topmodules?
Reply #1 - Nov 6th, 2009, 6:57am
Somisetty,
see Verilog-AMS spec (http://www.designers-guide.org/VerilogAMS/vams231.pdf) page 121 for an example.
BOE
PS: What is logicXXX in your code?
Riad KACED
Swindon, UK
Reply #2 - Nov 6th, 2009, 10:37am
Hi somisetty,
What don't you try the solutions we have provided in your previous post ?
2. Why don't you serach a bit this form as there are tons of exmaple already there ? Look at http://www.designers-guide.org/Books/dg-vams/index.html for example.
3. Why don't you look at the verilog-AMS documentation which provided in your IUS stream ?
You need to help yourself a bit ...
BTW, the codes you have provided are noing going to pass the compiler I'm afraid ...
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
somisetty
Reply #3 - Nov 6th, 2009, 9:51pm
Thank you very much
