Sep 28th, 2024, 10:25am
about breakdown voltage (Read 3106 times)
rajesh14
tuni, andhra pradesh
Nov 06th, 2009, 9:06am
can anybody say how breakdown voltage of a particular device plays an important role in RF/ANALOG Applications..?
View Profile rajesh14   IP Logged
HdrChopper
Re: about breakdown voltage
Reply #1 - Nov 6th, 2009, 6:53pm
Hi rajaesh,
Your question sounds like too broad. From a general perspective I think it becomes an important parameter every time the device in question goes conneted to an input/output pin, where high voltages might hit the circuit....
Best
Tosei
Keep it simple
Mayank
Reply #2 - Nov 9th, 2009, 11:10am
Hello rajesh,
                   The break-down voltage is a limiting voltage above which Source & Drain starts exhibiting very high conductance because of avalanche/Zener Breakdown Effect...In all applications including RF/Analog, we always operate much below the breakdown Voltage.....
        Special care must be taken to ensure that voltage across any two MOS terminals should not go above the rated operation voltage(like 3.3V mos, 2.4V MOS, 1.2V MOS)....Esp in the case of a change in supply domain, like at the inputs as Tosei suggested, we place special ESD/CDM devices to ensure that the MOSFETs never come under stress....
    i think that should suffice....
--Mayank
HdrChopper
Reply #3 - Nov 9th, 2009, 5:53pm
The temperature dependence of the BK voltage depends on whether it is Zener or avalanche. Zener BK depends on tunneling effect and its voltage decreases with temperature, while avalanche depends on impact ionization and thus the BK voltage increases with temperature.
Those temperature coefficients are sometimes used as reference voltages for some temp compensation circuits. That is another role that sometimes the breakdown voltage plays in analog design.
Best
Tosei
Keep it simple
Mayank
Reply #4 - Nov 9th, 2009, 8:33pm
Hello Tosei,
                 You mean as the reverse Breakdown Voltage in Zener Diodes used in reference ckts sometimes ??
--Mayank
HdrChopper
Reply #5 - Nov 10th, 2009, 3:57am
Yes... Gray and Meyer classic text book shows some examples of those.
Best
Tosei
Keep it simple
