Jul 16th, 2024, 8:59am
charge conservation problem in capacitor model (Read 4793 times)
applecore
San Jose, CA
Nov 08th, 2009, 11:19am
I am puzzled by a charge conservation problem of capacitor, and tried a spectre simulation to solve it. What I did is to put an ideal capacitor and an ideal inductor in parallel, set an initial current in inductor, and ran a transient.  The tank oscillates, of cause, but with a decaying magnitude. Then I tried the code in
http://www.designers-guide.org/Modeling/varactors.pdf
by replacing the nonlinear q = c0∗v + c1∗v1∗ln(cosh((v – v0)/v1)); to a linear q=c0*v. It turns out that this model has the same result as the schematic view result. So I assume this model has same problem with the schematic model, NOT conserving charge. What is the solution then? How to model a charge conserving capacitor?
Thanks~~~~
Ji
Re: charge conservation problem in capacitor model
Reply #1 - Nov 9th, 2009, 9:28am
For an explanation of what you are seeing, check out "4.2.2.3 Artificial Numerical Damping" starting on page 147 of "The Designer's Guide to Spice and Spectre" http://www.designers-guide.org/Books/dg-spice. To get rid of the effect, switch the transient integration method to trapezoidal (Spectre transient option 'method=traponly').
applecore
San Jose, CA
Reply #2 - Nov 13th, 2009, 4:26pm
Dr. Kundert,
Thank you for the reply! I found my answer with your help! The voltage dependent capacitor (varactor) distributes energy to harmonicas, and the oscillation decades if no energy is injected to the tank (gm cell).
Ji
