Jul 17th, 2024, 8:18am
VerilogA code of NRZI Encoder (Read 6145 times)
somisetty
Nov 11th, 2009, 11:00pm
The whole block diagram is USB transceiver is given below. I want to model only Encoder using verilogA code. Please provide proper code.
And also NRZI code example has given below as,
if '1' bit comes then transistion will happen, otherwise if '0' bit comes no transistion simply it follws the previous data.
Thank you inadvance
« Last Edit: Nov 12th, 2009, 1:36am by somisetty »
Riad KACED
Swindon, UK
Re: VerilogA code of NRZI Encoder
Reply #1 - Nov 12th, 2009, 2:48pm
Riad KACED
PDK, EDA Support Engineer.
