Aug 15th, 2024, 3:00am
Parallel input and Serial output (PISO) of USB tranceiver (Read 5113 times)
somisetty
Nov 12th, 2009, 4:32am
Can any one help me regarding VerilogA code for PISO block which is shown in below diagram?
Thanks inadvance
Riad KACED
Swindon, UK
Re: Parallel input and Serial output (PISO) of USB tranceiver
Reply #1 - Nov 12th, 2009, 2:47pm
Riad KACED
PDK, EDA Support Engineer.
somisetty
Reply #2 - Nov 12th, 2009, 9:20pm
Thank you very much
somisetty
Reply #3 - Nov 15th, 2009, 8:20pm
Hi KACED,
I could not able find verilogA code of Parallel input and serial output (PISO) under what you have mentioned. (http://www.designers-guide.org/Books/dg-vams/index.html).
Please give me some more information on that.
thanks
Riad KACED
Swindon, UK
Reply #4 - Nov 16th, 2009, 12:38am
Hi Somisetty,
I have never said there was any.
What I meant is given the few Verilog-A/verilog-AMS you have asked in this forum, you better take a look at the Book I have mentioned.
In other words, you better taked a week or 2 of your time, studying verilog-A and Verilog-ams languages. Once it is all clear in your mind, then you may start looking at the hundreds of examples in this forum.
You wouldn't expect people to write a tailored model for your very specific need, would you ?
Well, if you can't afford buying the book, which is fair enough, then You can look at either the Cadence's Manuals (I posted the links in a previous post) or the Accela LRMs. I can send the links if needed.
Riad.
Riad KACED
