HdrChopper
[quote author=Mayank_Singh link=1258556820/0#2 date=1258605890]Thanx Tosei, The input at Vin will change the current in 1st branch, changing the voltage at Vx...Opamp will try to settle Vy to the same voltage, & current in second branch will be decided by Vy/Rload & NOT VIN.....This action doesnt reflect a current source, instead a voltage source Am i mistaken somewhere ? [quote]
Hi Mayank,
In my opinion you do have a voltage controlled current source, since Vx is controlled by Vin, and Iout is a function of Vy=Vx. The observation is that the output current is not a linear function of the input voltage, but still it is controlled by it. What it looks to me is that if you want a more linear control on the current you then need to size the controlled NMOS such that it operates in triode region....
Best Tosei
