Sep 27th, 2024, 9:14pm
Pages: 1 2
popcorn noise (RTS noise?) in parasitic VNPN BJTs (Read 4924 times)
aaron_do
Nov 23rd, 2009, 3:54am
do we normally find popcorn noise in parasitic VNPN transistors? I was running some measurements on a circuit which used such transistors, and found what I could only describe as popcorn noise.
thanks,
Aaron
Re: popcorn noise (RTS noise?) in parasitic VNPN BJTs
Reply #1 - Nov 23rd, 2009, 8:36am
Absolutely!
Read up on shot noise in bipolar transistors.
Don't expect it to be modeled properly in Spice however.
-jerry
aaron_do
Reply #2 - Nov 24th, 2009, 1:13am
thanks for the reply. I read up a little about shot noise, but discarded it as it is supposedly white, right? I have included a plot of the output noise PSD. As you can see there are what appears to be tones at a few frequencies. The only noise I know which could exhibit this is burst noise.
Either that or the noise is coming from my measurement setup, but my setup appears to be quite clean of noise (I checked). I'm powering the DUT using AA batteries connected to linear regulators with lots of shunt caps. The only equipment used are a signal generator and a spectrum analyzer.
thanks,
Aaron
Reply #3 - Nov 24th, 2009, 7:07am
(1) What do you observe in DUT ?
(2) What purpose do you use signal generator in your spectrum measurement ?
    It seems you don't use signal generator in this measurement.
(3) Observe spectrum of ground without DUT or witout biasing to DUT.
When you try this, do spectrum spikes disappear ?
aaron_do
Reply #4 - Nov 24th, 2009, 8:00am
Hi pancho_hideboo,
the circuit is actually an LNA and mixer, so the signal generator provides the LO. I haven't checked the spectrum of ground, but i've checked some other nodes (LNA output node and a biasing node from a constant-gm biasing circuit) and no spikes are observed. I suppose that rules out noise on the ground node right? I've also tried turning off the LO and changing the biasing of the LNA. In neither case was the 3.5 MHz noise signal affected.
Unfortunately I can't run any further measurements on this circuit (in the near future) unless I can come up with a good explanation for this noise. Its on-wafer testing at my University, and there's a pretty big queue to use the probe station.
I'm not so sure that's its burst noise any more since the same noise component appeared on a separate chip. I'm not sure if it was the same wafer.
I didn't quite understand question (1).
thanks,
Aaron
Reply #5 - Nov 24th, 2009, 8:11am
aaron_do wrote on Nov 24th, 2009, 8:00am:
You observe IF output of "LNA+Mixer" in the conditions of the followings ?
    - RF is no signal feed with termination of 50ohm
    - LO is drived at some frequency by signal generator
What do you mean ?
What do you mean ?
You mean spike at 3.5MHz never disappear in any case ?
« Last Edit: Nov 25th, 2009, 12:46am by pancho_hideboo »
aaron_do
Reply #6 - Nov 24th, 2009, 4:22pm
   - RF is no signal feed with terminated of 50ohm
Correct
Quote:
What do you mean ?
If the 3.5 MHz signal were on the ground line then I expect it would affect all nodes, not just the output node. Is that correct?
Correct.
cheers,
Aaron
Reply #7 - Nov 25th, 2009, 2:31am
aaron_do wrote on Nov 24th, 2009, 4:22pm:
I think so.
aaron_do
Reply #8 - Nov 25th, 2009, 4:16am
I just realized that it might be common-mode oscillation which has been incompletely canceled by the differential operation. This would agree with the fact that my op-amp appears to have pretty poor IIP3. Its strange though since I normally overcompensate the CMFB loop since I only use it to set the output common-mode DC value...
Reply #9 - Nov 25th, 2009, 11:54am
Arron,
   It also might be due to a resonance in the supply lines, which would cause peaking in the noise.
aaron_do
Reply #10 - Nov 25th, 2009, 5:47pm
Hi Ken,
thanks for the reply. pancho_hideboo also pointed out that the ground line may not be clean, but as I mentioned, the 3.5 MHz noise only appeared at the output. I was only able to check two other nodes, but neither showed any evidence of a 3.5 MHz peak in the noise.
cheers,
Aaron
Reply #11 - Nov 25th, 2009, 11:18pm
Try to vary power supply voltage value to DUT.
Frequency of spike is still same ?
aaron_do
Reply #12 - Nov 25th, 2009, 11:52pm
Hi pancho_hideboo,
unfortunately, I cannot re-assemble my test setup at the moment. I did try changing the DUT supply and I did'nt notice any changes in the frequency of the 3.5 MHz noise, but I didn't record any values so i can't say for sure. I used a supply-independent biasing which means that the gain of my amplifiers wouldn't have been affected much by changes in the supply voltage.
thanks for the help,
Aaron
sos
Reply #13 - Nov 28th, 2009, 5:55pm
Are the frequency spikes constant, or do they vary?
Do you have a metal trash can you can put over your whole setup?
A metal trash can (with liner so you can remove the trash:) is a firm requirement for an analog lab.
Steve
aaron_do
Reply #14 - Nov 29th, 2009, 12:29am
Hi sos,
do you think the circuit might be picking up interference? The 3.5 MHz spike doesn't seem to move.
Anyway the probe station chamber should shield the wafer quite well from interference...i think.
cheers,
Aaron
Pages: 1 2
